Timbo would be the man to talk to. I need to reply to his PM. He seems to know what he is talking about very well.
This is all stage 1 we are talking about. On road, my boost keeps at 20psi. Pulls like a train after moving from boost 6 to boost 7.
Just gotta figure out a way to keep the pipe all attached without falling off.
I need to reply to Timbo's pm.
06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
Has anyone with a REVO tune had an engine failure and/or turbo failure?
i remember Guy saying any 20+psi of boost will prematurely wear out a turbo (on a k03 or k03s)
and that 17psi is at the very top of a k03 compressor map
Yeah I remember reading that too. I also remember reading that the APR v2 file spikes at over 20psi.(with mods)
All this bc insanekiwi mixed up the PM function ..high boost causing intercooler hoses to explode, irresponsible level adjustments, ...Tim must be going
Looks to me like boost on the REVO Stage 1 (when set to higher boost) is about the same as APR V2. A to whether it can 'take it', I guess that's a question for the developers.
Not that I am aware. I did a pretty thorough search before choosing REVO. Subsequently, I've read of a REVO flashed diesel with turbo failure, and then of an unflashed diesel with turbo failure ? Turbos fail for a range of reason, but poor oil quality/quantity is usually top of the list.
As to my problems with intercooler hoses coming off (they NEVER exploded ) I now know this is not due to boost, but is a design problem as it has affected another car as well. The first time it happened to me, it gave me big problems by throwing codes.
(WARNING: ) I directly advised the obdurate and lazy local dealer that intercooler pipe connection was the cause of the problem, but of course they were completely clueless and did nothing to rectify it, as I recently discovered. Probably, I should just use VW Assist until they get the message but it's easily fixed, at least temporarily.
2015 White German SUV
2013 White German hatch
2011 Silver French hot hatch
2008 TR Golf GT TDI DSG
Ok, interesting point. I'm only guessing, but I assume APR developers deliberately chose to cut off V2's power at 5000rpm for a reason, eg turbo spinning at extreme cycles after 5000rpm. ..also, there's big difference between merely spiking and sustaining very high boost levels into upper rpm zones. Those REVO settings sound like fun though ..
I don't think any tune/flash can hold 22psi in the K03s above 5000rpm. I know my tune never held it that long. I want it too though!!!! haha
