Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 63
Thread: THS Seat sport intercooler install pics
  1. #21
    May 2010
    S.E Melb
    So i finally had a chance to have a crack at this today. All fitted up and looking good. one problem. the fking front bar wont fit back on!!
    Cant find any pics to see if anyone had modified the front bar or any info as to whether they were.... what am i doing wrong?
    Here
    - top of the intercooler (and looks like the back of where the badge clips in aswell)
    And here (driver side foglight recess hitting the lower pipe work
    Any ideas? What am i missing?
    MY07 Polo GTi
    Last run - 114.8kw atw
    Winton - 1:52.7130
  2. #22
    Aug 2012
    Sydney NSW
    Get out your dremel!
    Cut out any areas that are touching.
  3. #23
    May 2010
    S.E Melb
    Re: THS Seat sport intercooler install pics
    Quote Originally Posted by Redliner View Post
    Fair enough. Just wanted to make sure that you guys cut a few pieces out aswell. Last thing I wanted was to cut it out when not needed!
    Will finish it off tomorrow. Time for a beer!
    Finished pic and final verdict tomorrow
    MY07 Polo GTi
    Winton - 1:52.7130
  4. #24
    Jan 2012
    Bentleigh East, Melbourne, Vic
    Yip, lots of cutting
  5. #25
    +1, feels like a massacre but it needs to be done.
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
  6. #26
    Jan 2009
    blankedy
    the most cutting is required behind the grill at the top. The Seat core sits proud, quite an obvious cooler, I think it looks good and sits well, but lots of plastic and clippy bits are no longer. Take your time, don't remove any more than you have to, its pretty easy to do a test fit after a little cutting.
    Tighten all the clamps some more, do a test drive before you put the bar back on if you can. I had to take it off again to kill a leak.
  7. #27
    May 2010
    S.E Melb
    Oh crap the test drive lol I was so focussed on getting the bar on I forgot about that!
    Will do that before I start hacking into the bar. Thanks for the heads up!
    MY07 Polo GTi
    Winton - 1:52.7130
  8. #28
    Aug 2008
    SYDNEY
    Also take some photos of how much to cut off as I will be doing this over the xmas break (if all the bits arrive in time!)
    2008 POLO GTI - SOLD
    2005 MkV Golf GTI - couldn't resist
  9. #29
    May 2010
    S.E Melb
    Alrighty. Im done. @AUC-05L ... I didnt take many pics of what needed to be cut. But I can specify where:
    - The plastic piece that the bar is screwed into at the middle has to come off completely.
    - D/S Foglight cover: The middle part of the plastic needs about half an inch taken off from the inside. The intake pipe hits on it as it curves around.
    - The inner foglight recess needs to be cut back... a lot... (Pics are above) otherwise the pipework hits it. Try to cut it so that the lower clip is still there because it will slide under the piping and still clip in
    - A decent chunk of the bar needs to come off where the grille clips in as the intercooler's outlet hits on the bar and the bar wont clip in properly otherwise (pics also above)
    - Note that you will only have two of the four clips left for the lower part of the grille (as the rest need to be cut down). But its fine, the grille is still held in by 4 screws at the top.
    - the 1st (driver side) clip on the grille itself needs to come off completely. The intercooler will hit it and the grille wont go on otherwise.
    It looks like a lot, but once it is all on, you dont see anything you have modified so it still looks like a very clean install (plus im anal so i sanded back and buffed the parts I cut back to neaten it up)
    Definitely a worthy upgrade. Same boost (for now) but you can definitely feel that the response has increased and it is definitely smoother.
    Hoses are on VERY tight, so I dont think they will be going anywhere.
    Final Pics:
    And here is whatever plastic I could find on the floor after we had hacked the crap out of it lol
    MY07 Polo GTi
    Winton - 1:52.7130
  10. #30
    Jan 2009
    blankedy
    Looks good, very obvious IC afterwards, but not so much as to draw attention for those who don't know the model.
    I have a theory that it makes its money back in long term fuel savings, or so I tell myself...
