Results 1 to 10 of 15
Thread: THS group buy
    Jan 2012
    Bentleigh East, Melbourne, Vic
    THS group buy
    Hi All,
    I have decided that I am going to buy a THS cooler (& forge pipes).
    However I thought I would also open it up to anyone else that is keen.
    I will be contacting THS (and forge), and trying to see what discounts we can get.
    If some pre-negotiations have already occureed, then apologies for jumping the line, and I will be happy to hand over to yourself.
    If however there have been no further discussions with THS, then I will call them a start the ball rolling.
    Just out of interest, who is keen....if no-one, then thats OK too, as I will need to contact THS either way.
    Clint
    Polo 9n3 GTI
    Jan 2009
    blankedy
    I'm interested in the piping kit, either procuring locally (bit more effort) or the Forge kit (much more expensive).
    May 2011
    CAMPBELLTOWN
    if you want to go for the cooler straight away
    Hold off on the Forge Gear for now, as they will need to be modified, also i am currently putting a kit together for all the pips silicone and clamps.
    Keep in contact with this.
    Matty
    GIAC | FORGE | D2 | TURBOSMART | K&N | XFORCE |
    May 2011
    CAMPBELLTOWN
    Matty
    Do the cores come with the required OEM brackets to mount it?
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
    Jan 2012
    Quote Originally Posted by spraycanmansam View Post
    No, this is an exta order:
    Bracket- 6LL1458808C
    Bracket 6LL1458808B
    Bolts to fit the brackets to the intercooler- N90280904
    Polo 9n3 GTI
    Jan 2009
    blankedy
    Nice work Matty.
    Support local where we can
    May 2011
    CAMPBELLTOWN
    What size is the air sensor have to be?
    Jan 2009
    blankedy
    Ideally something like this
    from Carformance:FSI/TSI MAP Sensor Flange - Stainless Steel Aluminium custom intercooler pipes plumbing weld mounting bung Aluminium threaded thread
    I have not come across many good fabricated options, so it might be easiest to get the bends in a group and we can get them done by someone locally. mounted into a 50mm section would work best with the kit piping sizes.
    Clicht, sorry for hijacking your FMIC thread with the piping details. Not seeing as much interest for the THS or Seat coolers as I had expected... Any bites?
    Jan 2009
    Bit of bad timing with the UR bracing group buy. I'm also sorting out brakes.
    To do the front mount, I'd be doing the dump pipe at the same time and a stage 2 retune which makes for quite an expensive month.
    Daily: 2010 VW Jetta Highline
