Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: For those with KW V1 Coilovers ...
    Aug 2009
    Belgium
    got kw coilovers for about 4 years on my GTI now.
    diddn't come with droplinks.
    i also driving for 4 years without the hight adjusters at the rear.
    done trackracing with it also and never had problems.
    nocking sound is gone when you put shorter drop links (i don't have them either)
    Jul 2010
    Hmm this may be a silly question, but are the rear adjustment perches supposed to be on the top or bottom of the rear spring?
    I've always seen coilovers with them installed on the bottom. I did a quick google search and saw some people mention they are meant to be on the top, with the OEM rubber base removed? Perhaps this is why the perch didnt fit snugly on the base?
    I hope i didnt have them installed upside down!
    MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
    Aug 2009
    Belgium
    the spring supposed to be installed above the adjustemt hight/lowering ring. (ring at bottom)
    so that the spring rests on the adjustment ring.
    if you turn the ring to the lowest setting, turned all the way down, the car will be getting lower.
    is this what you mean??
    Jul 2010
    Yes that is how i have it installed, wound all the way down but it is still too high for my liking so i want to remove the adjustment perch altogether. But i have seen pics where the purple adjustment perch is at the top of the spring?
    Aug 2009
    Belgium
    just get rid of the purple adjustmet ring, it will be at his lowest setting.
    why in the world would you put the ring on top of the spring??
    i don't see any benifit from that...
