2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
Just wanted to check. Is this the location for the CTS?
I don't think that's it mate. Is it in a plastic pipe? That looks more like the VVT to me.
Update:
I replaced the coolant temp sensor on the weekend even though when Gav did a full scan on my car and tested the gauges to make sure everything was working correctly it all came back clear. It's really strange, if I turn the car off then back on straight away it will reset to 0 but if I come back after say a half hour or so, it will show the correct temperature. Anyone have any ideas? Starting to think it mist be an electrical problem somewhere along the line?
Any help appreciated!
Don't have any ideas but my car is just started doing this too. What's really puzzling is an obd2 scan says the temp is normal (90 degc) when the gauge is reading zero. Gauge returns to normal after a few mins of driving
Must be a common Polo GTI thing as mine has just started this a few weeks ago, doesn't sound to be quite as bad as above but it will sit at about 70 degrees permanently, doesn't take long to get there but even after 6 hours of driving it won't spend much time at 90. I was convinced it was the CTS, will see if VCDS picks anything up. It probably should bother me more than it should, but it's been like this for a few weeks now haha.
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
