Thanks noone. All a learning process for me I guess. I've read heaps of your posts and you seem to know quite a lot.
Nothing wrong with being fresh, I'm still very knowledgeless despite my efforts.
Did you end up finding the problem? I have the exact same issue, can get it to 90c, turn it off and even if I turn it Back on instantly it returns to 0c. Also don't hear the SAI anymore on cold start ups. All coolant pipes are warm and no fault lights are coming up.
Any ideas?
2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
The SAI doesn't have to run every start, although they often come on on the first start of the day. Even with mine removed and coded out, I can hear the relay click pretty often.
Thanks Gav, any explanation for the temp gauge resetting to zero and then slowly moving back up to 90c everytime I turn the car on even once the cars warm?
Edit, I have made a video of what's happening too: Gti Polo Problem: Gti Polo Problem - YouTube
Any help is appreciated
Same thing happens with my Polo gti. After driving a while and turn the car off and turn it on shortly after temp is at zero and then goes back to normal after a few minutes of driving and I have a brand new temp sensor.
2007 Golf MKV 2.0 TDI DSG | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
If you can't then no one will be able to haha!
It's a weird one because you would think a new temp sensor would solve it with the mentality that the old one obviously is detecting temperature incorrectly when its restarted, thinking it's cold when it's really at 90c. However your not the first person who has replaced the CTS and had the problem continue.
Anyone else resolved the issue?
Tried to put an obd scanner on to see the temp reading as per the ecu? ECT is the obd code. To me that would rule out the temp sensor and push the issue back to the gauge itself.
08 9n3 Polo GTI
Mods: heaps
