The 96kW version never made it to Australia. We only ever got the 74kW version but they can easily be chipped to produce the same power.
Sent from my Moto G (5) Plus using Tapatalk
Hey guys,
I've recently been looking at purchasing a 1.9 TDI 9N and I've seen that there is a 74kw version and a 96kw version. I am just wondering if we ever got that higher power version, possibly in the later Pacific model?
I'd also like to know if there's anything to look out for when buying.
Thanks.
Resident grumpy old fart
Thank you!
Yeh I think I will do that whenever I get one.
The difference is MASSIVE so I highly recommend it. Plus you use less fuel when driving normally!
They're (Polo TDI) great little cars. maintenance is super easy (provided you have jacks and some standard tools), fuel economy is fantastic, there's now a s$#t-ton of parts for them for when you want to start modding, and when chipped, they will hold their own quite well, on a cruise day.
I actually miss my TDI. I wonder what it would be like now, if I hadn't been rear-ended by that Landcruiser.
