Results 1 to 10 of 17
Thread: Sway bar question
    Jun 2008
    Sway bar question
    So I've ordered a whiteline RSB today, on reading the instructions available online, I've realised the bar is to be mounted at the centre to the torsion beam itself and not the body/chassis of the car as I have originally thought.
    At first I thought it didn't make sense as the torsion beam itself is a big moving part pivoted at the trailing arms. Then I remembered the entire torsion beam axle IS a giant anti-roll bar by itself.
    So in effect are you just increaasing the stiffness of the entire torsion beam axle by adding a sway/anti-roll bar?
    Jan 2008
    Melbun
    what car pal?
    surely if its a new polo it has independent rear suspension?
    2x Caddy, 1x Ducato
    Dec 2006
    mischa it doesnt
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
    Jun 2008
    It's a Pog - which has never had independent rear - been a torsion beam setup since 1975.
    Even the Golf has always had the same design up until Golf5.
    Most small hatches still use the torsion beam -you could call it semi-independent at astretch because the wheels do move independently to each other to a small degree but not fully independent.
    Aug 2008
    Liverpool, Sydney
    has anyone ever put a frount strut brace for thier polo?
    Sep 2006
    Brisvegas
    Yes mate there is quite a few on here with a front strut brace. I myself have a front strut brace and rear swaybar on mine.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    S.E Melbourne
    Anyone running a rear strut brace?
    Sep 2006
    Brisvegas
    as far as i know poloGTi is. Most ppl dont want to have to drill through the plastic in there boot to install it.
    Have a Look
    CUSTOM CODE
    Phase 2
    Jan 2008
    Quote Originally Posted by shaneth View Post
    Is it only the platic you have to drill through? No metal drilling?
    Mar 2006
    South Hobart Tasmania
    No plastic to drill through just carpet to cut with the rear u only need a 12mm hole through the carpet.
    This is the hole in which i use to secure the rear strut brace.
    Forge uses the same fixing hole on there model.
    A bolt can be placed through from behind if a bit of hassel.
