Heh, funny as
On the same topic, look at this, there is a video explaining it
Volkswagen Golf VI 2.0T Suspension Subframe ES#421475 Subframe Spacer Plate - Priced Each - 7M3499349A
Yep prob not the brakes, still getting it, times like this I wished I had a gopro
2016 Golf R, APR Stage 1
2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
I've got gopro's, what are you thinking and I can try replicate.
Daily: 2010 VW Jetta Highline
** All information I provide is probably incorrect until validated by someone else **![]()
Was thinking of securely mounting it under the car near the front wheel and trying to replicate the problem, would give more of an indication as to where the sound is coming from, ecs have a few vids like this![]()
Removed the Ultra Racing Strut bar and replaced the original strut bolts, got a feeling its the bolts or the bar, either way I'll give it a week and see how it goes, if no rattles i'll replace the bolts used on the bar with longer factory style bolts, this may be the remedy.
After removing the strut bar, the issue is definitely better, only managed to make it occur on extra bumpy surfaces, possibly still an issue with the strut top but I think this has nailed the issue..
Will organize some bolts and see if it goes away with the bar in, if not the extra torsion may be the issue..
Think around 50,000k's you start to hear a whole heap of new noises in the car, nothing major, just gets you wondering..
But I think this suspension knock is possibly a minor design bug with the car..
