wheel spacers needed!
I very quickly need some 5 x 100 PCD, 57.1mm CB and about 5-6mm thick spacers. Anyone got anything fitting that description that's sitting on a shelf. Preferably aluminium. My new wheels are a papers width from the calipers and the valve is grazing the caliper too so need some spacers to get some breathing room. 5mm should do it while still allowing the hub centric ring to go onto the hub. any help much appreciated.
thanks
sam
- You may not post replies
- You may not edit your posts
Forum Rules
