Results 11 to 20 of 22
Thread: super vibration
    Nov 2012
    WA
    Running all 3 vibratechnics mounts, vibrates a bit more obviously but 0 dramas so far from any of them.
    08 9n3 Polo GTI
    Mods: heaps
    nsw
    Yeah someone else on here had one completely distintegrate and mine has gone loose and now spins. When I went to remove it when I did the farb it had spun a full 180 degrees and due to the way the relief is cut in its top surface, couldn't get the dam thing out of the steering crossmember without skinned knuckles.
    Oct 2013
    yeh when i get the new one im gonna stikaflex it in i did it with the stock one just now and the car has been the smoothest i ever had it gearshifts are perfect. but my engine mounts are really bad and that would be putting more stress on the dogbone mount so ima hold out putting the new one in intell i do the engine mounts
    Sep 2006
    Tweed Heads
    Hoyhoy.
    I would like to jump in here to share something that I found recently with the vibra-technics left gearbox mount, I'm sure I was the first to get these mounts in Aussie so I had the earlier mount from before about two years ago which were a sh*t design.
    Only found this fault when I went to bleed the clutch which is done after removing the air filter box, battery & the left engine mount.
    I had been chasing this clunking noise for sometime & then wallah.
    I've been in contact with them & all they would tell me was that the earlier design was redesigned with no sympathy to my case.
    So I had a good look @ the original mount & found it to be much better than their earlier model.
    If ya a look @ the shiny metal part, you'll see what I mean.
    The round collars done nothing, I wasn't too happy, but found the standard one great.
    The right hand mount is a different story, much better.
    Hooroo.
    Oct 2013
    damm the looks like a weird design the new design looks to be alot better and alot of people say good things about them hope they
    work out good.
    Attached Thumbnails Attached Thumbnails super vibration-vag200m_1229-jpg
    Nov 2012
    WA
    Thou hath the revised mount
    Is good
    08 9n3 Polo GTI
    Mods: heaps
    Melbourne, Vic
    Im guessing your cupholder is useless now, had the superpro in mine for about a year, the rattling of the cupholder drove me mad!
    Back to the stock mount now
    2016 Golf R, APR Stage 1
    2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
    Oct 2013
    Quote Originally Posted by flat6 View Post
    there was no vibration and everything was smooth with the superpro bush the 70A one tell it gave in then it was crazy
    Cup holder blew apart before I got my Polo. So that vibration is the least of my concerns.
    The Race dogbone isn't even that bad IMO.
    Vibratechnics mounts are great but $600 is a lot of money if you don't need them. My gearbox one was flogged out, the engine one I would put back in if I had to.
    Nov 2012
    WA
    I had a 9N previous to the gti and the engine mounts failed.
    May be expensive but the stock gear won't last forever.
    Preventative maintenance!
    08 9n3 Polo GTI
    Mods: heaps
