No.
The 17" rims require lower profile tyres and these are
- Harder to find/fewer options for semi-slicks
- More expensive
- No benefit
- Heavier overall due to the added rim weight being greater than the reduction in tyre weight
for track usage. Get the smallest wheels that will fit over your brakes.
Unless you want to use the 17's for daily drive and use the 16's you have for tracking (assuming you haven't done a wheel size upgrade)
Resident grumpy old fart
