Results 1 to 10 of 14
Thread: Suitable Track Rims?
    Apr 2010
    Hey Guys,
    I'm looking for a set of cheapish track rims. A friend has some spare 5x100 rims from his '99 WRX.
    Does anyone know if these rims will fit?
    I have stock calipers.
    melbourne
    hey man,
    with the subarus the center bore is different so you'll have to get them bored out from 56.1mm to 57.1mm in order for them to fit onto the hub.
    on top of that, the et53 is too high for the polo - you'd have to run like 10mm spacers on the front to clear the calipers, and that's quite a large spacer to be running under stressful track conditions, especially with all the weight and work taking place up front.
    obviously there are people out there who've run spacers on the track with no issues, but if it were me i'd go for something with a lower offset that you dont have to drill the center bore out of.
    what is your budget for wheels only?
    Apr 2010
    Thanks for the info Scott. The price range I'm looking at is $200-$300, excluding tyres.
    Eltham, Victoria
    Quote Originally Posted by End User View Post
    There are some Audi TT compomotive rims on eBay at the moment, pretty sure their starting bid is at $200 if you're interested.
    I've got no connection to them by the way, I just have 5x100 saved as a search item haha.
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Buller_Scott View Post
    I'm no great fan of spacers but if they are proper hubcentric spacers, the loading should not be an issue since the spacer will transfer the load from the wheel to the hub. A 15mm spacer (which will give an offset of 38mm) may actually be preferable from this point of view as there will be more room for the spacer to be fully supported by the hub.
    ICHIBA V1 15mm HUB CENTRIC WHEEL SPACERS 5x100/112 57.1 14x1.5 BALL BOLT BLACK | eBay
    H&R 15mm DR Wheel Spacer 5x100/57.1/14x1.5 Volkswagen Passat 1990-1997 | eBay
    Resident grumpy old fart
    Jun 2009
    This.
    You don't want to compromise the car/wheels by altering them further.
    Anby particular reason you are going for OEM Suby wheels, i thought they would still be weighty.
    You should be able to jag some performance alloys (Oz/Enkei) for $200-300 per wheel
    Feb 2008
    ACT
    I'm a fan of the original TT wheels for the track - they're cheap, fit perfectly even over modified brakes and seem to be readily available on eBay and the like. They are fairly heavy but as a result they're also extremely tough for those times where you ride the ripple strips or just balls things up completely and end up bouncing through scenery into the kitty litter.
    I picked my first set back in 2008 for about $500, and a second set a couple of years ago off eBay for $250, so they should fit your budget.
    Eltham, Victoria
    melbourne
    Quote Originally Posted by Bflat View Post
    there you go!
    get on it, End User
    Oct 2010
    Melbourne, VIC
    No.
    The 17" rims require lower profile tyres and these are
    1. Harder to find/fewer options for semi-slicks
    2. More expensive
    3. No benefit
    4. Heavier overall due to the added rim weight being greater than the reduction in tyre weight
    for track usage. Get the smallest wheels that will fit over your brakes.
    Unless you want to use the 17's for daily drive and use the 16's you have for tracking (assuming you haven't done a wheel size upgrade)
