Results 11 to 20 of 22
Thread: Stuffed wheel bearings?
    Eltham, Victoria
    My rear left bearing is on the way out also. It wasn't too bad two weeks ago but it's pretty loud now. The most annoying time is when it's only slightly mismatched to the frequency of the exhaust note (wawawawawawawa you get the drift).
    I'll drop it off soon to be pressed out and have a new one wacked in.
    Jan 2009
    blankedy
    I don't think the rears have to be pressed out, apparently the rears are easy (rear left seems common for some reason) and fronts are a pain.
    Jan 2009
    blankedy
    Picking up on this as the bearing (or whatever it is) is now getting pretty loud.
    Looks like you can't just buy a new bearing? Can anyone look it up on ETKA / ETC please?
    Feb 2007
    Brisvegas
    Mate why don't you just buy the KMAC strut tops. You will never need to replace the bearings again as they would survive a nuclear war and I'm guessing if you have to buy the complete OEM tops it is probably going to cost more anyway. Plus you'll love the camber!!
    Jan 2009
    blankedy
    Thats true, but I'm not talking about the strut bearings, I'm talking about the thing that lets the wheel rotate... It sits inside the hub.
    Also, its for the rear.
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Scruffy View Post
    Hey guys, I hit a pothole the other night which blew out my front right tyre Since then I now have a slight grinding noise from that side of the car.
    Are you sure you don't have something rubbing on a drive shaft? The bump might have knocked things out of alignment.
    Feb 2007
    Brisvegas
    Sorry I thought this was the noise from the top of your strut. Wrong thread?
    Jan 2009
    blankedy
    Yeah, I have another noise in the front end, not yet tracked it down.
    Aug 2007
    I think we talking about wheel bearings, if it is fronts be ready for Elm street. The 9N3 have Gen 2 wheel bearings and cant be done the conventional way ( press out and press in) totally different, reason i say it is ive done a few. there is a special tool which is needs the Liberian deficit to pay for it. I ended up figuring out a way without the special tool, pm me if need be. If your mechanic does it without the right tool or at least being super super careful he will for sure stuff it and itll be $250 down the drain leaving it still needing a bearing, anyone who has done it or knows someone who has will know where im coming from. They have a special snap collar on the bearing that comes with the hub. Try to fit it the normal way and you will snap the collar for definite. like i say ive got a way round it as ive done a few 9N3s but would be crazy to broadcast it to all the experts so please pm me before you stuff it.
    Cheers.
    By the way SKF do a kit rather than VW but still reqs the tools or the "other "way.
    Jmac
    ps the dealer doesn't have the tool generally , they normally hire it from Sydney overnight to do the job.
    Alba European
    Jan 2009
    blankedy
    i think this is what I need, can anyone comment on what else would be required
