Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Stuffed wheel bearings?
    Jul 2009
    Hey guys, I hit a pothole the other night which blew out my front right tyre Since then I now have a slight grinding noise from that side of the car. I put the spare on and I have checked the wheel nuts which are tight!? The sound is also louder the harder I brake or corner. Could it be that the hit has damaged the wheel bearings?? I haven't had a chance to take the wheel off and have a decent look yet. Any other ideas?
    Feb 2008
    Quote Originally Posted by Scruffy View Post
    Sounds like it I'm afraid. Lift the wheel off the ground and try and move the hub laterally, and see if there is any Freeplay there.
    Jul 2009
    Everything looks to be good. The only thing I can think of is that it actually sounds like the tyre making a squeaking noise against the rim! Maybe its not seated properly!
    Oct 2009
    Canberra ACT
    Mate, my bushings went when I hit a massive pot hole last year. wasnt really making noise though.
    What rims are you running?
    Jul 2009
    Just stockies, but its the first time I have used the spare so it may just be that tyre.
    Oct 2010
    Melbourne, VIC
    Try swapping the spare across with the other front to see if the noise moves.
    Jan 2009
    blankedy
    what rims? if they are aftermarket your spigot rings may be munted.
    Jan 2009
    blankedy
    Think one of mine has gone...
    Anyone else dealt with this?
    Unsure if I should tool up or get the shop to do it.
    Are you saying a bearing has failed?
    Jan 2009
    blankedy
    I have a noise which is noticeable at 60kms and gets louder at higher speeds. Had the parcel shelf out yesterday and was very noticable. Not sure what else it would be, all spins freely and tyres look normal.
