Hey all,
This noise has been plaguing me on and off for about a year.
You can hear it toward the end of the crappy video I took and is a ticking/grinding noise that occurs whenever the car is rolling. Doesnt matter if its in gear or not or if I am using the brakes it still occurs.
It gets worse if I turn to the Right and is proportional to the speed of the car.
I took it to VW once and they put it down to "brakes rubbing" but it is still annoying me.
It sounds like maybe my right CV/wheel bearing is stuffed ?
Its a 2006 model with <40 000k's. I have had both control arm bushes changed to the better ones (thanks jmac) and also the APR dogbone engine mount installed.
You can hear it clearly at about 20 secs
Any thoughts/knowledge greatly appreciated!
Thanks
Justin
