Results 1 to 10 of 17
Thread: Stock rubber dogbone mount bush
    Jun 2008
    Hi folks
    Is there anyone in Sydney with a stock dogbone mount (rubber) bush that they don't need? I've swapped mine for the PU one, yes the shift quality has noticeably improved (wasn't bad to begin with), yes the clutch take up point does feel more distinct but it's also true the car does vibrate a fair bit more at idle especially with the a/c on - can't stand that any more, lesson learned.
    As I'm contemplating selling the car later this year it'd probably make sense to return that to stock so it won't scare the punters off (unless they're enthusiasts like you are )
    So, just wondering if:
    a) does anyone have a stock bush lying around that you can donate/sell me for a small sum, or
    b) does anyone want a swap for a small sum (to me of course) - we'll probably need to be somewhere with the right tools to fit it though
    cheers
    If you can't find one to swap you can order the complete arm with bush from VW for ~$80.
    Found out about the vibrations the hard way like you
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
    Eltham, Victoria
    Which bush did you upgrade to?
    I put the Superpro 70Strength in mine and only notice a slight increase in cabin vibration when the air/con is on.
    It was only a $70 part IIRC.
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by spraycanmansam View Post
    Really? I thought you had gone more hard core and upgraded to the VibraTechnics complete replacement arm.
    As for swapping the torque arms, the only tools needed are a T20 torx bit (and driver) and a 16mm socket, driver & short extension. The hardest part is getting under the car to access the arm.
    You should try a diesel for vibrations with the polyureathane bush
    Resident grumpy old fart
    I had an APR which from what I remember was around the 90 shore mark. If I was going to go back to a PU bush Id go for the Superpro as it's softer. Kaanage, I didn't mind the bush but the missus wasn't too happy with and she drives it most of the time for work I've replaced it with the stock arm for the time being. After I find where the knocks in my front end are coming from I'll look into it again.
    Polo GTI MY2008
    Build Thread
    Eltham, Victoria
    I'd be careful about knocks coming from your front end.....I had one on saturday night that turned out to be a shot wheel bearing....it wasn't an enjoyable noise!!!
    Oct 2010
    That's good to know, thanks. Like Roodosutaa I'm changing back from the APR to the stock mount because it's too harsh.
    Mar 2007
    Gold Coast
    Have you checked your rear control arm bushes and sway bar drop links? Common cause of knocking.
    Feb 2008
    I'm surprised that people are finding the APR mount harsh... Honestly, I can't feel it. I have had it in for 100,000 km now.
    Aug 2007
    Quote Originally Posted by Blitzen View Post
    You got an APR mount, ive had a few Polos that were meant to have one and once the were flogged turned out to be a Superpro bush. i refitted with a Super Pro mind you , i like their products. Was taken aback to see how bad the last 2 ive done were, they were (APR) superpro bushes.
    Jmac
    Alba European
