The peak looks ok but I don't remember a drop off to 2 psi at redline being normal and the over/undershoot after the peak looks a bit ragged. If you look at Gavs build thread at about page 5 onwards he has included a standard tune dyno run you could compare to. But then again the required and actual boost traces do mimick one another quite closely. If the actual was well different to the required I think thats when you'd start to stress. But it seems that the MAP pressure is matching what the ECU/N75 is asking for.
- You may not post replies
- You may not edit your posts
Forum Rules
