Results 1 to 7 of 7
Thread: Stereo Installation.
    Feb 2008
    Hey, Have any of you guys changed the standard stereo head unit? I'm looking at putting in a Kenwood double din screen unit, but I was wondering if there was any special considerations that I should know about if I was to get it done?
    vanilla5 Guest
    i have upgraded to a single din alpine. so i can put the gauges in the dash. not on top of the dash like the ford xr6t
    Jan 2007
    West Perth
    ive added a kenwood double din screen and it fits a treat
    Feb 2008
    Thanks guys for the feedback...I was worried about the CBUS cabling, but if that dosn't have to be touched, thats awesome.
    Nov 2007
    I've been there with a full stereo install before in the Polo. One thing I must point out is that a Japanese double din isnt a European double din. Per say, if this is going into a 9N Polo, then you fill find a small gap between the centre console/air con module, and your head unit. The gap isnt evident but it's there.
    To help minimise this, you can spray the headunit's sleeve a matt black on the outter lip. This helps to conceal the metal that is sometimes visible.
    Also ensure that your headunit isnt too long. For instance, I've previously had a JVC AVX1 headunit and an Eclipse CD-5444 installed in mine and both were reasonably long headunits and at times didnt fit properly (until proper force was used).
    Removal of the stock headunit is simple - just use 4 of those Kenwood 'keys' that are supplied to remove your Kenwood headunit. Slide them into the blank slots and you're on your way (this applies only to a 9N3). If you're removing the headunit off a 9N2 (which I've done before for a friend), is a bit different. Remove the lower pocket first and you should be able to slightly jimmy out the stock headunit.
    Last but not least - make sure you secure the leads from your new headunit to the stock vehicle cluster.
    Hope this helps and good luck.
    GTI|BBS|Forge|Whiteline|Custom CAI+K&N|Sparco|Toyo|Martini|JVC|Focal|ScanGaugeII
    Jan 2008
    Cremorne, Melbourne
    i have a kenwood single din head unit. the space above is now filled with a plastic to hold stuff, looks great
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
