Hi,
Before placing any orders, I thought I would open this up and ask you what you prefer / what is beter ad why -- Steel or Alumiium strut brace).
Thanks
Hi,
Thanks
Polo 9n3 GTI
Hey mate, the only difference is weight and strength. The steel option is A LOT heavier as it's a bigger brace than the Forge.
did you go for the red steel / aluminium
Polo 9n3 GTI
I went steel in the end like my lower brace from them.
Another thread on this http://www.vwwatercooled.org.au/foru...ium-68364.html
Resident grumpy old fart
are the strut towers close enough to the firewall (chassis) such that technically, front strut tower bars dont serve any real purpose other than a cosmetic one?
One of the few mods I did on its own. With an old config it reduced the tendency of the inner wheel to slip when powering out of a corner. That was with H&R springs, stock FSB and shocks.
I have had the Forge item for nigh on 4 years now. It's hollow aluminum. I felt the difference straight away after fitting. Having a look at the other brace, I have to say that I do like the look of it, and it does look stronger, however, I certainly didn't buy my Forge one for the look of it.
At the end of the day, it's your cash.
