Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Speakers on polo...?
  1. #21
    i was quite ****ty that there was no factory audio system upgrade option.
    means i have to DIY
    oh well, looks like the rainbows come out of retirement... now i just need somewhere to fit the bloody crossovers
  2. #22
    Plenty of room in the kick panels, or up a little higher if you need the real estate.
  3. #23
    Jul 2007
    Durban, South Africa
    the stock phillips speakers are decent enough - ive got the rear ones still connected to my aftermarket headunit and ive got a set of MB Quart Q-LInes up front - so basically my audio is comparatively high end - but hey i actually like the stock speakers for rear fill - they work well enough
    BTW Bose = buy other sound equipment - its basically high priced junk IMHO
  4. #24
    Quote Originally Posted by naughty View Post
    Damn straight!
    Dynaudio is where its at
  5. #25
    Kuala Lumpur
    Quote Originally Posted by Stuwey View Post
    Damn straight!
    Hahaha, didnt know got Dyns supporter here. Used to run Dyn MD130 tweets on my previous ride, such clarity and richness I'd say, just lack of bass and slower than Scanspeak.
  6. #26
    I've never owned Dyn stuff for the car - I'd love to run the Focals that i've had for years with a nice Eclipse amp once i buy a new HU.
    I went looking for a home stereo about 5 years ago, with a budget of 3k. I ended up spending $6k just on Dynaudio speakers alone!
    I do love my driving music
  7. #27
    Quote Originally Posted by j0n_GTI View Post
    hmm kicks would suffice nicely. Might pull off a few panels to investigate on the weekend
  8. #28
    Kuala Lumpur
    In here, we're able to go for good used product so not as expensive as it should be
    Home audio is way expensive to me, so much has to be taken into consideration but end result is way better !
  9. #29
    Jul 2007
    I'm thinking of getting the HU changed to old school Alpine 7998R or 7935, Scanspeaks Reveletors drivers and 12" sub, TRU T4.150 amps. Should be alright for entry level system.
    that would be more than entry level - if installed properly it should sound terrific - i like tru amps and scan speak revelators are legendary speakers - not sure which 12" sub you intend using but there are lots of good ones out there
    in terms of the sub im going to replace my JBL 15" with a morel ultimo - should sound a little better - wish i could afford Morel supremo components upfront but they are a tad bit expensive here in South Africa - and then the related amps and cabling could get expensive too ..... i am also considering replacing my Kenwood K-CD01 headunit by an alpine 9887 with imprint module - that thing has everything including the kitchen sink but right now my install is still a little old school with that CD player and phoenix gold amps
  10. #30
    Kuala Lumpur
    I was going put RS 12" sub (forgot which model though).
    About the 9887, might as well you go for good conditioned unit from Pioneer P9 or 9835. Sounds better IMHO. But then needs to find faceplate to cover the hole
    Can the front door panel accommodate 7" drivers without modifying it?
