Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Thread: Spacers
  1. #41
    Jan 2010
    Scotland UK
    Quote Originally Posted by Whubbsie View Post
    won't look the same your arches will sit closer to the wheel, actually 35mm is a pretty good drop for getting a 17" rim smack bang in the the centre of the arches some spacers to get you 5-10mm of poke and you'll look sweet and ride comfortably.
    any serious drop you'll need coilovers even then only ones I've seen that go lower than 75mm are H&R ones
    Thanks for all the advice people. I really dont know why VW didnt make the wheels 17 imo it would look much better.
    Thanks Guy
    2006 Polo GTi Black | Leather, Nav, Cruise Control, Parking assist,BMC CDA, Phillips Diamond Vision, Black/Red emblem, Custom remap 199bhp, 35mm H&R
  2. #42
    May 2009
    S.E. Melb Vic
    Mate im running 17x8 w/ a 45 offset, than spacing back out to what would equate to; front 11mm spacer or new offset of 34, rear 16mm spacer or new offset 29, downfall is when you re-adjust coilovers to set low its hard to drive on bumpy surfaces, rubs everywhere, but looks the goods. now to drive it the it was ment to be driven I take it up 25mm rear and 35mm front, but now you can hit it hard and even brake harder,
    Just my fifty cents worth.
    Cheers ssman
  3. #43
    Jan 2010
    Scotland UK
    Well ive decided to go for 17" x 8j offset of 33 lowerd 35mm with a profile of 45 should be okay?
  4. #44
    Jan 2009
    blankedy
    Quote Originally Posted by GuyGTi View Post
    Good luck finding those wheels... Generally Offsets of 32, 38 and 42 are OEM, there are lower offsets, but less common.
    Changing the rolling diameter will change the speedo, etc. 40 profile is the correct match for 17's.
  5. #45
    Jul 2007
    Durban, South Africa
    that depends on the width of the wheel
    the profile is actually the percentage in millimeters of the tyres width
    so a 40 profile for a polo will only keep the rolling diameter constant is the width of the tyre is 205. but nevertheless a 45 profile while seeming safer is definitely going to change the rolling diameter of the complete wheel unless its on a very narrow tyre
    the trick to this profile business is to remember that what it means is that the sidewall is going to be the profile percentage of the tyre width so its got a relation and it isnt a constant measurement - it varies according to tyre width
  6. #46
    Jan 2008
    Canning Vale, Perth, WA
    this site allows you to play with tyre widths and profiles to keep the same rolling diameter
    http://www.miata.net/garage/tirecalc.html
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
  7. #47
    Jan 2010
    Scotland UK
    Quote Originally Posted by gareth_oau View Post
    Great! So if i get a 205 40 17 (bit of stretch) Then it should be almost exactly the same apparently
    Thanks for that site very handy.
    Guy
