Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: Something to watch out for: loose turbo bolts!
  1. #21
    Aug 2007
    Quote Originally Posted by Jmac View Post
    Ive cut down a crappy spanner mate, with a nice goose neck. This is good for checking and loosening, but on tighten up with new bolts and gasket you really need to torque them up to 40 NM, with high temp assembly paste, so the spanner wont help you there, but at least itll do to check them.
    Jmac
    Just to add i fitted new bolts today and they were 17mm. This is the second 3 to be replaced. Last ones were 16mm go figure? They must have a batch of both. Good thing is the 16mm swan neck i made up was the other half of a 17mm swan so 2 tools made up for the price of one FTW.
    Lockwiring them tomorrow by the way drilling the hardened bolt heads are a large job and will take ages. Nearly 2 hrs to drill 3 bolt heads!!!! im drilling another set next size up so drill should be cheaper.
    Ill let you know when it happens
    Jmac
    Alba European
  2. #22
    Nov 2008
    Canberra
    Don't want to start a bidding war on this, but my turbo bolts (06 build) are DEFINITELY 17mm. So maybe some cars have 16 and some 17 - seems strange though ..................
  3. #23
    Nov 2006
    Yes, I know I'm a dodgy mechanic, but I have the barely sufficient competence to recognise when I'm using a 17mm spanner on a 16mm bolt
    Hope your solution works, Jimmy!
    2015 White German SUV
    2013 White German hatch
    2011 Silver French hot hatch
    2008 TR Golf GT TDI DSG
  4. #24
    Apr 2006
    Hobart,Tas
    Rather than drilling the bolt heads it might be easier to make up a lock plate?
    Cheers,
    Andrew
  5. #25
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Me still as tight as a virgy with the drilled & wired bolty's.
    Hooroo.
  6. #26
    Aug 2007
    Yeah old ones which were VAG were 16mm and the new ones straight from VAG are 17mm, crazy hard as coffin nails. i have them all drilled, latest ones i drilled for 20 thou lockwire, i did this by mistake, but the spec i used when in the aircraft game was 31 thou. i have another set of bolts being drilled 35 thou to accomodate 31thou wire. My recent ones im gonna run with 25 thou see how it goes. I am however heaps more confident with the 35 thou as i have along with an aircraft engineer tested it with extreme heat direct and took a bit to snap. Lets remember it isnt direct heat but transfer, im gonna use a infrared thermo on the turbo to see exactly what it is for fun.
    Stay tuned , and like a good friend sayed today im sure my new lockwire pliers are gonna be busy
    Jmac
    Alba European
  7. #27
    Dec 2006
    Gold Coast
    http://www.ausrotary.com/viewtopic.php?f=4&t=179974
    Ill be watching this thread.. See what some rotor geeks come up with.
  8. #28
    Aug 2007
    After LOTs of pondering i am visisting an engineer tomorrow to confirm if my new idea is going to work, in my minds eye its a belter. i have successfully lockwired a K04 with 31thou lockwire and as ive already mentioned im having a longer set that with go onto a meaty manifold and K04 being drilled out to 42 thou for 35 thou lockwire, and ive also mentioned i spent some valueable time at an aircraft shop with the engineer testing the wire with heat. i figure this with my new fix if i pull it off will then become a 2 lock system thus making it hard for the bolts to loosen
    By the new fix isnt studs or tabs, very different
    Stay tuned
    Here is sneak peek at the lockwire, but like i say there is an extra marvel going in there soon hopefully
    Jmac
    Alba European
  9. #29
    Jan 2009
    sunshine coast
    awsome jmac nice work.
  10. #30
    Aug 2007
    Took my latest idea, and by the way i have thought this one up lying in bed so blame the subconscious mind for this one!!! I ran it past the engineer today and he actually smirked and said mate is going to work. I am pretty exited about it, stay tuned for this, i will test run it on K04 install that will be happening soon and then i will offer it to any casualties, otherwise let sleeping dogs lie, ive seen Pogs with 90k and the bolts are good, and seen them low kss loose. Ive seen locktabs mentioned, wirelocking which i still might do as a secondary anyway and studs and nuts, This one is close to locktabs but not quite this one is one more level over that.
    Thats all for now
    Jmac
    Alba European
