From all that i read, the exhaust mod does nothing more than add sound, the stock setup is actually fairly good
What benefits do you guys see from the APR R1 dv? worth the upgrade?
06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
T Go
MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
I think the dump pipe is limited in its benefits, but they are certainly there. A little more power, a throatier burble when the exhaust it warm, but not WRX'y... The cat is holding it back but they're not cheap to swap out, if you know someone with the tools / ability, a used one in good cond could be a cheap option.
As for the intake, I still remember the clear difference with the boost coming on in 1st gear, if you are not considering other intake options, its worth the spend in combination with a tune and decent diverter.
Many options, difficult to know where to spend it. I stated doing a writeup, trying to explain how it all came together on my car, you may find it helpful.
Enjoy (I think you might be doing that as I type)...
You could also choose a GFB dv instead of the apr or forge. I preferred it over the forge dvMade a massive improvement on the polos drivability!
So i got it. First time in a while i actually drove to work. First time i have ever enjoyed it too. I got heaps of reading to do as well when i comes to the mods everyones suggesting. What about weight of car? Anyone done any simple weight reduction? Surely a new full exhaust would weigh less than the original.
Thanks Chuck ill keep in mind when i start to look at the upgrades. Will be nice to see the difference.
Noone - ill check out the writeup.
Thanks everyone again.
