Originally Posted by
simon k
thanks guys
I've been told where I can get 2nd hand slicks for a good price, and given I'm in the same class as some cars that are basically out-and-out race cars on semi-slicks it doesn't really matter if I put myself into the race car class. I just want to go faster... is 350lb in the right ballpark for them too? does a stickier tyre require a stiffer spring?
Daughter took some really poor photos; this is a reasonably flat corner where the inside rear doesn't pick up as much as the big sweeper. I think it also shows that I do need more rear camber, something I've been putting off
The problem with a full slick is that are very particular about set up, they only operate within narrow windows. For example the spring rate has to be right and will vary from track to track and with conditions. They also have a narrow tolerance level for camber and caster, get outside of that and they will overheat, blister and tear themselves apart fairly rapidly. It takes me almost a full day of testing to get a new car on full slicks in the 95% window. Plus I will kill at least one set getting there.
In comparison semi slicks are far more tolerant, they have much wider window in which they will still operate quite well. I can get a semi slick shod car in the 95% window in a couple of sessions without damaging the tyre at all.
That's with fully adjustable rigid chassis race cars, for a flexing road car with all of the compromises that brings personally I'd stick with the semi slicks.
I'm gradually getting Sam to setting up the rear with 6mm of toe out and 2.5 degrees of neg camber, mm by mm.
Gary
