Page 36 of 44 FirstFirst ... 263435363738 ... LastLast
Results 351 to 360 of 431
Thread: simon's learning what to do with the polo thread
  1. #351
    Oct 2017
    Wodonga, Vic
    there's a good post on this exact subject on this page - saying the same (I think!) as you Gary - and almost directly stating that TT uprights are the go
    VWVortex.com - Roll center adjusters/ball joint extenders
  2. #352
    Oct 2017
    Wodonga, Vic
    here's another interesting read: Roll Centre Correction - The Pinderwagen
  3. #353
    nsw
    I did look briefly into the audi upright. We know that Audi ball joints fit our upright so know that ball joints will fit in. I assume tie rod ends would be easy. The question is will the driveshafts fit ( I know track people in the UK have mentioned running Audi driveshafts as ours were getting expensive?) and will our struts match the upright too. Apparently the ones you want are Audi TT Mk1 pre-recall - the recall where they added the rear gurney flap on the boot and swap uprights. Apparently the thinking was that you shouldn't let people on the road have uprights with good camber gain because they will just grip grip and then let go when the tyre gives up. Far better to have an upright like ours probably that starts to plough understeer you the moment you go above 7/10ths so that you can always get it back and can never get to a point where you are at a fatal speed when you leave the road.
  4. #354
    Oct 2017
    Wodonga, Vic
    sometimes I amaze myself... I took the rear springs out and cut about 20mm off them, just by eye... put them in, measured the rake off the jacking points like Gary said, 10mm down in the bum. 185mm at the front and 175 at the back
  5. #355
    nsw
    wisdom right there. nice work.
    That second post you added is a beauty. I wont try explaining roll centre/ball joint location to people ever again, I'll just send that.
    I think the problem with ball joint extenders on our hubs is that you still cant lower the car easily without mangling the steering angles very quickly too. The steering rack simply cannot be raised and you'd have to go custom on the tie rod end side to correct there.
    That's why the Audi TT spindles look the goods as I'm sure they'd have ball joint and tie rod end positions in step with one another. Didn't know they are alloy too!
    That leaves the diameter of the receiver for the strut tube and the driveshaft fitment to confirm. If that's a go then you'd also be swapping brakes over with it, ABS sensors etc but that wouldn't be too bad - probably couldn't run 15's over those brakes though.
    I could be wrong but I still swear I heard that even within MK1 Audi TT there were two different spindles and that the recall had something to do with that so not all spindles were created equal within that model.
  6. #356
    Oct 2017
    Wodonga, Vic
    seen this? Vehicle Suspension: Front View Online Suspension Simulator - need to take a bunch of measurements but interesting to play with once they're in there
    definitely worth having a good look at some TT spindles, I'd be pretty confident that the strut tubes are the same size, the CVs are different but there ought to be some combination of parts that works
  7. #357
    nsw
    I've heard of Audi A3 driveshafts going in I think.
  8. #358
    Oct 2017
    Wodonga, Vic
    reasonably happy with the sprint at Winton today - tyres and suspension took 2.5 seconds off, and it was a much hotter day so that could easily account for another second - but not enough laps for the money - it works out at $7.50 per lap. 4 sessions of 4 laps plus 4 laps practice. Not enough seat time I reckon
    my best time was in the last session, I'd learnt how to take some corners better by the end of the day, but my 2nd best time was in the first session when it was cooler.
    Something was wrong during the 2nd session, the car just felt sluggish - after the chequered flag I was enjoying the feeling of the airconditioning cooling my hand through my glove... oh sh*t, idiot... I reckon that took 15kph out of the car on the main straight
    During the 3rd and 4th sessions the temp gauge was getting up to the 110° mark, and I assume the ECU was cutting timing as it felt doughey after the first lap or so as the temp crept up. I could hit 160 along the main straight on the 1st & 2nd lap, struggled to get to 150 after that
    I think I have also experienced boiled brake fluid for the first time; the pedal is spongy for the first half of its travel and will pump up pressure as if there is air in it. I'll bleed it after tea and see what comes out. I have a couple of bottles of the good high temp stuff that's been recommended on here, and it's probably time I fitted the new rotors and pads I bought last year.
  9. #359
    nsw
    That's a pretty fat improvement. Which tyres did you run? That's why I did my oil cooler - its always been known that oil temps get way up but they drag the water temps up too via the heat exchanger. Whether it dumps fuel or pulls timing I'm not sure but I haven't felt that yet. I know Sean in QLD temps says he's felt it quite often.
    My mate is building a Clio RS and I nearly died when I saw how much the firewall/master cylinder moved. He made up a nice brace for it with associated heat shield and it is rock solid now, so after seeing that and after what you just mentoned I'm a bit inspired to do that now.
  10. #360
    Oct 2017
    Wodonga, Vic
    Quote Originally Posted by sambb View Post
    F: A050, R: R888R. I took the NT01s with me, but left them off. On paper the A050/R888R combo is the best, widest wheel, widest track and better tyres...
    yeah - I read all of your posts about it - I'll go back and review... basically bypass the water heat exchanger and add a sandwich plate for the oil cooler, yeah?
    My mate is building a Clio RS and I nearly died when I saw how much the firewall/master cylinder moved. He made up a nice brace for it with associated heat shield and it is rock solid now, so after seeing that and after what you just mentioned I'm a bit inspired to do that now.
    I was talking more that I reckon there is a change in the pedal pressure when I was driving home. It just felt like the pedal was going further to the floor. I bled both fronts. The fluid was darker than I'd expect, and a little bit of air came out of the left. Not sure...
