Page 34 of 44 FirstFirst ... 243233343536 ... LastLast
Results 331 to 340 of 431
Thread: simon's learning what to do with the polo thread
  1. #331
    nsw
    A050 is a hot range of 29-32psi I think. I think 30-31psi is usual. Gary would be able to confirm though. Not sure re the Toyos though I have heard they prefer a tad more air than the A050's eg 32psi. The Nt01's I dont think are an R spec, more like a UHP street 'semi' so would need to be higher I'd think ie due to less sidewall/carcass structure. My AD08R's were best around 34 and that seems to go for RSRR's, R1R's and the like. I don't think the NT01's will hold a candle to the R specs but are street legal so could be used there. No doubt they'll go harder than the RE003's though.
  2. #332
    Apr 2015
    For A050's we aim for 30 psi, 31 is OK, 32 at a stretch but much over that risks blistering. Avoid starting pressure lower than 24 psi as the tires will spin on the rims under braking (ruins the balance real bad). We run markers on the tyres and rims to detect any movement, a quarter of a turn is not unusual on the front.
    Gary
  3. #333
    Oct 2017
    Wodonga, Vic
    gotcha - stick with what I've been doing then the first sprint is on 17th Feb, getting a bit itchy to go fast again...
    I'd like another set of wheels so I can mount the NT01s - I was offered a set of 15" Audi wheels last year, but they're only 6" wide... really too narrow (aren't they?)
    The NT01s are very similar to the R888Rs, google says they're a semi slick... Though the guy who gave them to me went from them to 2nd hand slicks and picked up 3 seconds with his Nissan powered clubman
  4. #334
    nsw
    yeah 6in is a bit narrow for 205's. 6.5in far better. 7in best. Actually yeah you're right they are classed as a semi. I think I read in the past that NT01's had been the same compound as R888 just with a different tread cut. apparently co owned and out of same factory - but that was the interwebs telling me that. Now that we have R888R I'm not sure where NT01 fits relative to the Toyo. Be interesting what their relative weights are. I had a Toyo rep tell me that an R888 soft compound (back when they existed) was still harder than an A050 medium. R888R pretty much only come in medium now. They may be a softer compound now, who knows, but I think the A050's will be the stickier tyre.
  5. #335
    Apr 2015
    Based on my experience 205's on 6's would be OK, plenty of guys run 225's A050's on 7's and they are baggy (237mm wide).
    Gary
  6. #336
    Oct 2017
    Wodonga, Vic
    thanks - I'll give him a shout. It'll give me a way to use the NT01s, even if it works out that I run 7" wheels at the front and 6" at the back (or some combination)
    I assume running wide tyres on a narrow rim makes the sidewalls flex and roll-over more than desired - more air pressure if that happens?
  7. #337
    Oct 2017
    Wodonga, Vic
    updating Gary's list - I'm doing OK !
    Quote Originally Posted by Sydneykid View Post
    #1 Rear swaybar (or beam stiffener) nothing else comes close, bang for buck CHECK
    #2 Front positive caster, the more the better CHECK
    #3 Front negative camber for obvious reasons CHECK
    #4 Rear toe out, ask Sam CHECK (have room for a bit more)
    #5 Lower the rear roll centre CHECK
    #6 Dampers, buy the best you can afford CHECK
    #7 Front roll centre correction and bump steer elimination
    #8 LSD
    #9 Rear springs, at least triple the standard rate CHECK
    #10 Front springs, ~1.5 times the standard rate CHECK
    #11 Front swaybar
    Not sure if I've asked what to do with front roll centre correction, or what's wrong with the stock roll-centre. I'll do some reading
    I'd like to understand body bracing more, and whether it's really worthwhile. Opinions on front strut braces seem to polarise between "utterly awesome and essential" to "dodgy snake oil that doesn't do anything". I look at lots of different setups on cars and the ones that actually seem to have some purpose is where the bar ties the towers together AND back to the firewall. AE92 Corolla SX (4AGE engine) have this setup standard. Toyota tend not to do things to add bling, they'd do it because it works, right?
    then there's the rear, do things like this make any difference?
    these seem a bit pointless
  8. #338
    nsw
    Being a rear beam the rear strut brace only stiffens the damper tower. I do think they stiffen the body which is a bit prone to twisting. Pretty sure I've banged on about it before but my rear hatch wouldn't close properly when parked on a slope - the striker wouldn't line up so the body had to be twisting. On my drive way the inside rear will be 2 inches in the air and if you rock the chassis you can hear it creaking and watch the door gaps change. This would definitely be happening during cornering so I reckon particularly the first brace would be great.
  9. #339
    Oct 2017
    Wodonga, Vic
    Quote Originally Posted by sambb View Post
    true... I was going to do that driveway twist check but forgot all about it
    I might draw one and see what my waterjet man will charge for it. The row of screws along the top edge of that one go into what looks like a piece of RHS, I don't really see why that's necessary unless the whole "web" idea is just wank. A cross bar like this could work just as well (if it works at all)
    it's pretty hard to find actual empirical tests that prove that the strut towers flex, and installing a bar reduces it...
  10. #340
    nsw
    yeah I don't think its the strut towers flexing independently due to suspension loads (the traditional mc strut problem) because they don't take loads in that way. The only things up there are the dampers. But the floor would definitely have pretty massive load torqueing at it as the twist beam twists for sure. I think its those twisting loads that move the whole body. But the towers are a convenient way I guess mounting something to combat that and triangulating the forces from them to the floor might be a good way to stiffen things up. While you're at it you may as well make the main bar out of the right tubing diameters so that you can hang a harness off them in the future.
