I've been caught out a couple of times interstate without my camber gauge and used my phone instead. I just cut a piece of aluminium angle to the right length so it sits on the rim, stick the phone to it with some blue tack or double sided tape. I even used velcro once. Using that, camber is easy to measure, just correct for any ground slope.
For measuring caster, which is camber change over +20 and -20 = 40 degrees of steering angle, I get the wheel aligner to tell me how many turns of the steering wheel equals 20 degrees. Then I write that down in the book, that lives with every car I look after. So when I want to do an alignment at the track I only need to turn the steering wheel the appropriate amount (ie; not use turn plates). I do roll the car back and forwards a little to release any angle restriction from the turning. At home I have 2 pieces of 3 mm thick alloy sheet, greased in between, that I use as cheap (and lightweight) turn plates.
Of course these days "book" equals iPad with settings loaded in the cloud so that I can pull them down anywhere anytime.
Gary
