Originally Posted by
Sydneykid
Hi Simon, if you want a priority list for FWD suspension;
#1 Rear swaybar (or beam stiffener) nothing else comes close, bang for buck
#2 Front positive caster, the more the better
#3 Front negative camber for obvious reasons
#4 Rear toe out, ask Sam
#5 Lower the rear roll centre
#6 Dampers, buy the best you can afford
#7 Front roll centre correction and bump steer elimination
#8 LSD
#9 Front swaybar
#10 Rear springs, at least triple the standard rate
#11 Front springs, ~1.5 times the standard rate
Most people are surprised that I put springs so low on the list as it's often the first thing people reach for, when there are things that make far more difference.
Gary
