looks good Simon. I mounted mine vertically but canted back at the top. Its always worried me that a ground strike on that corner could hurt the bottom of the cooler. Yours looks to be a bit less vulnerable than mine.
To be honest I just used -AN fittings because that's what my cooler came with. They turned out to be atrocious - all galled up on the seating surfaces and leaked. Definite lesson, never used second hand AN fittings. I ended up shelling out a again for Aeroflows which made the leaks better but yep I struggle to find the dollar value in them for most applications.
Having used push lock -AN fittings on my catchcan though, I'm sold on those. So quick and easy for the hose termination and then the convenience of being able to undo them.
Hey just be careful with whatever the braided lines touch. They are literally like a file and will go through anything the rub on. Where mine trail down off the oil filter housing towards the cooler, one of them just touches the belly pan. It has literally filed its way into it and is nearly through.
I'll be super interested to see how quickly your oil temps come up with that 90 degree thermostat in it. I found that water temps hit the mark much quicker without the oil slowing it down, but that my oil temps would get to the thermo's 80 degree mark and then really take its time to get beyond that to get to 100 and thats with it blanked off completely for anything other than the track, even in summer. Hope your is a bit better tailored for the street than mine's been.
oh and make sure you crank it for a bit with the fuel pump fuse out and really make sure the oil lines and cooler are primed. There's a lot of extra oil capacity in them.
