Originally Posted by
sambb
Yep nice one. I'd much prefer it nice and solid like yours rather than using the Speciality shims which just don't look rock solid. I was very tempted to use the 1/2in but would have to have flared the guards massively if I was ever to run 215 rears so used the 3/8's. I went from 5mm toe in total or something like that to zero toe and then out again to 2mm to out. I'd be surprised if it doesn't feel way better now for you. Although you probably have double the camber at the rear compared to the fronts now which might dull the overall effect.
The shims are sandwiched so it doesn't really matter how "solid" they are. As long as the bolts don't loosen they are trapped. I've used them for more than 15 years on all sorts of cars, many more higher powered, with much bigger wheel/tyres and way heavier than a Polo. We did a 12 Hour at Bathurst with a set in Swift, followed by 2 x 6 Hours, one at Sandown and one at Eastern Creek, then a 2 Hour at Philip Island. Then they did 100,000 k’s in a Swift road car.
Gary
