Originally Posted by
sambb
yeah with a tonne of rear anti roll it sounds like you are over powering the diagonally opposite front which goes into pos camber with that much roll angle on the car. That's why I did the FARB in mine when I had the B8's - stiffer springs were going to be hard to find so the bar was the next best thing. Still doesn't help front end dive resistance though
What rears were you running - the stiff cut ones or the H&R's? Its possible that you had excessive rear roll resistance and dialling it back a bit could have kept the front end a bit more in its window? 3 wheeling is good for front end grip but skimming the deck is what you want not half a foot in the air. Given what you have on hand I'd get as much camber from the BJ's as you can and try the H&R rears.
Is your rear track similar to the front track now that your stub spacers are in?
