Originally Posted by
simon k
erk.... do they even have a rear roll centre in the first place???
Yep, typical trailing arm roll centre, to lower it (which we absolutely need on a FWD car) we need to raise the outer trailing arm pivot on the body. Or lower the inner. The problem is there isn't enough room to get the roll centre even to ground level, let alone below it. The other issue is the camber moves at the same time as the roll centre and to get the roll centre low enough we end up with a lot of (too much) negative camber. Plus of course we want to toe it out a bit and that also means moving the inner and/or outer pivot points for and aft.
There's this one control arm that looks after roll centre and toe plus static and dynamic camber. This is the common "old" car problem, we can't fix one thing without screwing something else up.
Gary
