I'd say the reverse, myself
Do the 42DD bushings first - then consider Forge. I have one, but personally I wouldn't really bother with it. Bushings however, made huge difference. From what I can recall - there are 2 types of bushings. Get both.
06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
Resident grumpy old fart
I fitted my Forge SS a few weeks before fitting the 42DD bushes (mainly because the SS arrived first and I'm slack).
I found that with just the Forge SS, as well as greatly shortening the fore/aft throw (with the SS on the tightest setting), the shift feel was noticably more precise in this plane as the pin was a tighter fit than that on the stock shifter.
With the 42DD bushes added, the shift feel was also tightened up in the lateral plane (may have been a touch tighter again fore/aft). I don't feel it was worth the hassle/expense after fitting the Forge SS, though (I did do at least one track day between fitting the Forge SS and the 42DD bushes and still don't think it made for a massive improvement). Part of the hassle with the combination is that the larger pin on the Forge SS requires the corresponding 42DD bush set to be slightly drilled or machined out as it is designed to tighten up on the OE pin.
I would choose either just the Forge SS alone or else replace the lot with the DieselGeek Sigma SS.
My Polo only had about 25,000 km on the stock shifter/bushes so it is conceivable that a higher mileage model may find the 42DD bushes make a bigger difference.
I got my Forge SS from the group buy and Greg Roles (Carformance.com.au - great guy BTW) sells the 42DD bushes and DieselGeek SS.
Thank you Kaanage, a very articulate, helpful response and appreciated too. Cheers Al
