Page 2 of 2 FirstFirst 12
Results 11 to 20 of 25
Thread: short shifter!
    Oct 2010
    Melbourne, VIC
    The Forge one is very simple to install if you have a heat gun.
    However I did help install one where the fat cylindrical shift pin (the one used on our cars) did not have the thread properly machined on to it.
    Resident grumpy old fart
    boxhill
    since u live in melbourne, you should help me when i'm installing it thanks HAHA
    Jan 2009
    blankedy
    If you want one it's linked above, the Forge one...
    Or did you mean how its fitted or other options?
    I thought someone was angry at me when i saw the title of this thread. All good, continue.
    I did a search and that failed me. Yes options and availability and suitability. Feed back from those who have ss installed? I assumed there are various makes and some are better than other. Cheers Al
    PS All ShortShifter no issues with you lol
    Jan 2009
    blankedy
    There are other threads, it's good, you buy it from Forge, they likely have stock...
    This forums search feature is not fantastic. Use google: "site:http://www.vwwatercooled.org.au/forums/f127/ short"
    Lots of threads come up for me, it's not too hard to install, I was able to do it without removing the battery.
    Jul 2007
    Auckland, NZ
    Do the 42DD bushings first - then consider Forge. I have one, but personally I wouldn't really bother with it. Bushings however, made huge difference. From what I can recall - there are 2 types of bushings. Get both.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    Oct 2010
    Melbourne, VIC
    I'd say the reverse, myself
    Quote Originally Posted by kaanage View Post
    Hi Kaanage, a more articulate response would be good. So your saying that Shifter bushes and short shifter as a matched set works and from what supplier, price? More information gentlemen please? Cheers Al
    Oct 2010
    Melbourne, VIC
    I fitted my Forge SS a few weeks before fitting the 42DD bushes (mainly because the SS arrived first and I'm slack).
    I found that with just the Forge SS, as well as greatly shortening the fore/aft throw (with the SS on the tightest setting), the shift feel was noticably more precise in this plane as the pin was a tighter fit than that on the stock shifter.
    With the 42DD bushes added, the shift feel was also tightened up in the lateral plane (may have been a touch tighter again fore/aft). I don't feel it was worth the hassle/expense after fitting the Forge SS, though (I did do at least one track day between fitting the Forge SS and the 42DD bushes and still don't think it made for a massive improvement). Part of the hassle with the combination is that the larger pin on the Forge SS requires the corresponding 42DD bush set to be slightly drilled or machined out as it is designed to tighten up on the OE pin.
    I would choose either just the Forge SS alone or else replace the lot with the DieselGeek Sigma SS.
    My Polo only had about 25,000 km on the stock shifter/bushes so it is conceivable that a higher mileage model may find the 42DD bushes make a bigger difference.
    I got my Forge SS from the group buy and Greg Roles (Carformance.com.au - great guy BTW) sells the 42DD bushes and DieselGeek SS.
