Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Seriously...
    Aug 2007
    Inner West, Sydney, NSW
    Seriously...
    Does anyone find that any keys hanging from their car key smack into their legs whilst driving? Also, is it just me or do people find their legs smacking into the bottom of their steering wheel as well?
    Maybe my driving position is all wrong
    On that note, what is a good driving position for control and comfort?
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    Quote Originally Posted by MKIVF View Post
    Have that problem in the Jetta, but mainly due to the dealers big keyring dangling off keys.
    My biggest annoyance is no light on ignition on steering, so at night can't find the hole.
    Mar 2008
    Canning Vale, WA
    I always have trouble finding the hole....
    T Go.
    Jun 2007
    Quote Originally Posted by T Go View Post
    T Go.
    Maybe I should have rephrased that better.
    Jan 2008
    Legs almost straight (left leg should be about 150 degrees when on the clutch), vertical seat back. Set the seat height so your head is not far from the roof but far enough not to hit in on bumps.
    Mar 2008
    Canning Vale, WA
    I was always told that a good place to start is when you straighten your arm and place it on the top of the steering wheel, that your wrist should rest on the top of the steering wheel....
    T Go.
    Jun 2007
    Quote Originally Posted by neil View Post
    Led with your chin there didn't you?
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Aug 2007
    Quote Originally Posted by tosspot View Post
    Vertical seat back eh?
    With my legs nearly straight, my seat nearly touches my back seat. And I'm by all means not tall (5 foot 10 or there abouts)
    May 2007
    Burleigh Heads, Qld
    I find the most important thing is that your arms and shoulders be relaxed.
    To this end I sit quite close to the wheel and have the seat up high - I'll often even have the wheel at the bottom of its up/down range and extened towards me. And I'm 6'3".
    This way the wheel is sort of in your lap and arms very bent and relaxed. that way you are driving with your forearms and not your shoulders and torso.
    Have a look at a V8 Supercar driver or Nascar driver next time.
    This gives you the best control.
    Jan 2008
    Canning Vale, Perth, WA
    I recently attended an advanced driver training day at AHG in Perth.
    They advised that 90% of drivers sit too far from the steering wheel. The idea of placing yr wrists on the steering wheel is 'old school' thinking and is too far away. Also yr seat-back should be almost vertical and not laid back.
    Have a look at racing drivers, they sit quite close to the wheel and vertical
    The logic behind this is when yr arms are bent you get a lot more leverage and can react quicker than if yr arms are straighter.
    so stage 1 is to make sure yr seat is almost vertical.
    stage 2 is to slide the seat forward until your arms are quite bent.
    For me, the wheel is now about 30cms from my chest.
    (now if you have very long legs and short arms, this is going to be a bit tricky!!)
    It felt weird making the change initially, having being taught the "wrists" method so many thousands of years ago, but I stuck with it and now it feels much better.
    The instructors also advised that you should place yr hands on the wheel in the "quarter past three" position and not the "ten to two" position, again improving yr leverage.
    you shouldnt remove yr hands from the wheel but cross yr arms over, unless you are doing a very tight turning circle.
    The old push-pull steering routine was created for drivers of old buses and trucks with 24 inch steeering wheels and no power steering - it is no longer relavant in today's environment.
