Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 74
Thread: Secondary air pump problems
    May 2011
    Perth
    What sort of sound are we talking about. Mine makes a loud whining sound when i turn mine on and i didnt think anything of it. Also where to i need to look to check this.
    Jul 2007
    Auckland, NZ
    Jmac, so if my secondary pump is working well now - what can I do prevent this to happen? check for the combo valve and gasket regularly?
    That coil recall is interesting. I will call VW and ask. My car was on the road in Feb 2006, so probably manufactured in end of 2005.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    Jul 2010
    Bulleen, Melb, Aus
    I took my car in aswell to get the central locking fixed and they booked me in again a week later for the recall. At uni atm.. but will check my car later for the recall code. Pretty sure it was the coil pack... was about 4 months ago..totally meant to mention it haha
    Feb 2007
    Brisvegas
    Can you provide any more info on this? Recall ref, coilpack code, etc? Not sure where I would start, but always interested in a free repacement of potentially dodgy parts.
    Sure can... Recall: 28F5 - Fit 4 x Coil Packs. Part No. VW06A905115D
    Seems to be 05-07 builds from my snooping around the net and affects Polo GTI, Passat V6, Golf GTI, R32 etc...
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
    Apr 2008
    Swanbourne, WA
    Hey guys
    I've had a light come on in my dash and had it read by golfwagen, they believe its the secondary air pump. Has anyone else had the light come on?
    Golfwagen want to double check the relay and other possibilities first before they replace the air pump. I'm hoping its just a relay/electrical issue.
    Aug 2007
    Had another yesterday, real bad, filled to the neck in water and air cleaner element saturated, and of course MIL on. No noises coming from this one as its fully drowned. Ran the car with the SAi corrugated pipes off and watched the spatter from the combi valve. Dont think it only happens to Polos, got a 307 Pug doing the same. Doesnt happen to them all but i would probably be asking you friendly tech to check the pipes and pump for any signs of moisture every service, costly if it gets hold of it. Way out is removal, some of the guys are trialling just that at the moment on here. All good if the MIl stays away,if you do remove it and do the mod then you will of course have more black smoke on start up as the super rich exhaust wont have extra air , no big deal really. im looking forward to see how the mods go to see if the lamp stays out.
    cheers
    Jmac
    Alba European
    Apr 2008
    Swanbourne, WA
    Quote Originally Posted by Jmac View Post
    cheers
    Jmac
    Mine was like this. Philip at Golfwagen said he took it out and turned it upside down and a tonne of water came out. Fixed now under stat. warranty.
    Aug 2007
    Perth, Australia
    this would apply to mk4 r32s too?? If so where do i find this air pump?
    1991 BMW 318is RED E30
    Apr 2010
    Quote Originally Posted by ml16 View Post
    Mine was denied under warranty
    They said the only way water could get into it was because I drove through a flood
    Dealers suck balls.
    Aug 2007
    Quote Originally Posted by End User View Post
    Dealers suck balls.
    Totally not mate, think you would be getting a new engine if that were the case hey. They are going to see more believe me.
    Hope they replaced your combi valve mate otherwise it will happen again
    Jmac
    ---------- Post added at 06:54 PM ---------- Previous post was at 06:50 PM ----------
    Quote Originally Posted by balkanac View Post
    Ah mate, i think you will right, im pretty sure its the short route between the Pog pump and the combi valve. Havent seen any R32 dramas to be fair, im sure you should be right, im running the R32 motor in my Passat ill be sure to keep an eye and update if need be
    Jmac
    Alba European
