The SAI pumps tend to die with age.
If you disconnect the pipes from the pump (located behind the grill in front of the engine), you may find there is water in / around the pump.
Some have had success with resistors to make the ECU think its there, but I don't understand why, the issues tend to come from a/f ratio issues from what I can tell, not just an electrical load.
If you can clear the code, may have just been a random fault.
Do you notice a stuttery or lumpy idle after starting? The SAI pump is only used for the first ~30 sec after a cold start.
