Unless you are really after a factory appearance I reckon they are a rip off. You can nearly buy an anti roll bar for that much. You can still modify the cold air feed like you would with a PD160 fitment (trim out the flap) but the pipe itself is just that - a pipe. I bought a stormwater/gutter 30 degree (I think) fitting and heated it with a heat gun so that it was a moulded push fit into the back of the CAI mouth. Paint it black and then buy some convoluted black induction tubing from autobahn/supercheap etc (they come in a kit with clamps) and run that between your Bunnings downpipe fitting and the airbox. Even if you don't make the fitting you can just push the convoluted pipe inside the back of the cold air feed and it'll do the same job.
