Sounds good Funkdancer. Also please tell us if it gives the correct speedo reading as well please. Look forward to seeing what you think as i would be interested if it does.
Hey,
Following up on my earlier posts in this thread, my 2nd unit designated for my Polo just arrived @ work. It was ordered Sunday a week ago. Pretty quick delivery; exactly same experience as last time.
The whole purchase w/delivery etc clocked in at exactly AUD$199.95 on my Mastercard. It was ordered from http://www.scangauge.com - just ignore the bit about them not delivering outside of USA/Canada.
I'll set it up for my drive home for work, make note of whether there is indeed a proper turbo boost reading and will try to post pictures by tomorrow night.
First of all, it does not report the boost![]()
Whilst the MAP figure is appearing in my Euro, it's blanked out in the Polo. Other than that it works very well. The ECU is actually reporting a speed which is 3-4% faster than real; i.e. I had to dial it down by 3-4% in the SG.
My tyres are around 35-36PSI though, this might have something to do with it. In the Euro at the same PSI however the speed is darned nigh spot on.
I haven't gotten the good GPS out yet though, so relying on the roadangel at the moment. The Roadangel EVO's GPS is nowhere as good as that of the Garmin. I'm at a -4% correction now and it's probably a toss between that and -3%.
Fuel usage is reported different; SG2 says it is a bit higher than what the Polo's computer says it is. This might be a function of some conditioning required, I need to tell the SG when I've refueled - which I'll do tonight, and then next week when I refuel again I'll be able to adjust the percentage it is calculating by (the SG will tell you how much fuel it thinks you put in, and then you adjust it up or down - and it will learn from that).
Very important to always update the SG when refueling, otherwise things related to remaining tank mileage go a bit/completely out of whack.
Other than that, installation is a complete snap, it blends beautifully into the cockpit, looks awesome with backlighting set to blue. Will have to do something about the cables, at the moment the spare cabling is just sitting bundled up in the long coin/mobile phone tray under the wheel.
Photos to be provided soon.
Thanks for this. Am looking forward to photos and also would be grateful if you could report exactly what parameters it reports/monitos from the Pog's ECU
Funkdancer - the reason the MAP figure appears in the Euro and not the Polo is that the polo uses a MAF sensor...
The Accord Euro use a MAP sensor on the K24 to measure the pressure difference in the intake plunum AFTER the throttle body... The polo on the other hand uses a MAF to meter the airlfow BEFORE the throttle body.
There are pro's and con's for both systems... i prefer a MAP sensor to a MAF (they tend to be more reliable)... if you want to see boost you will have to tap a gauge into the little line leading to the wastegate![]()
Ah, thanks for that, Spec
A gauge would be much more useful anyway, I don't think you should be looking down at a small LCD too much under heavy accelleration.
Ok, some photos are uploading at the moment, the above is the first (shot with flash). Note that for the other darker shots, if any photographers are here, yep that's some dust on my sensor.
For normal driving the SG2 lines up perfectly in the middle of the dash LCDs. I only have to lean slightly to either side to see their outputs. As such, it fits better than in my Euro where the info LCD is obscured unless sitting up.
The data supported in the SG2 are ALL of the modes reported in the v2 manual on http://www.scangauge.com/support/ , or more specifically http://www.scangauge.com/support/pdf...anual_2_51.pdf , EXCEPT for that of MAP and FPR.
I've quoted the settings in below, both for my own reference and your benefit.
I'm gonna watch the F1s now, if anyone wants me to report on certain values please let me know and I'll answer as well as I can. I'll make another post with more shots when they're done.Originally Posted by SG2Manual
Ok, here we go. :) The LCD background colour is programmable, and the blue matches that of the Polo almost to a dot.
Hope you won't find these too large; hate posting thumbnails when using a good camera. ;)
If the police dont like you they will Defect you![]()
Why is that?
nice gauge!
you cant be defected for steering column mounted gauges or in dash gauges.you can be defected for on top dash mount or pillar mount as you can hit your head in a accident ,im lead to believe from my copper mates.
love the LED readout!!! keep up the great postings funk!!!![]()
