so there's been a bit of action on the blue Polo latel. Some of it welcome and long overdue, others far from welcome.
FULL REAR BEAM SWAP
A few things prompted this. The blue car came with Audi TT vented rear discs and calipers. I've been pretty unconvinced of their necessity to be honest. For the extra pretty significant weight they add to the unsprung mass I'm just not sure they are even required. I had reshimmed the bean so that it was running similar geometry to the beam on my silver car, so suspension setup was more or less equivalent. Despite that it just felt heavy and lumbersome, didnt ride bumps well causing the ESP and ABS to jump in at bad bad times eg over rumble strips where it never did that on the other car. While they may have operated cooler due to the venting, the calipers were a fair bit bigger/heavier, yet the pad size was identical between the stock rear brakes and these. The Polo has a much more weight forward weight split than a Golf 5 or Audi TT that these bigger rears were intended for. Recently also, Wakefield park has shut leaving Luddenham (a go kart track) and SMSP (south circuit, north circuit and full circuit) as the only circuits I have access to. In general I'll be predominately on the less demanding braking tracks or doing hillclimbs where brakes are hardly even used, so again the need for the bigger rears seemed to not be justified.
The beam on the blue car also had superpro two piece rear beam bushes that looked to be an imperfect fit - you cant swap them out without removing the beam completely anyway. Also the other beam has spacers fitted to it to widen the rear track. I've wanted to move away from wide 225 rear rubber back to something smaller like 205's (I used to run 195 softs in the hillclimbs!) so to maintain a wide track but with skinnier rear tyres, I'd need these spacers. So in the interest of going back to a generally lighter rear end, with solid 1 piece beam bushes and track widening spacers, it was time for a full rear beam swap to tackle 3 things with 1 physical job.
When doing a rear beam (including re bushing) you HAVE to crack the brake lines and fully remove the beam. The time required to then get the other beam back in means you need a fair bit of bleeding afterwards. I rigged up this gravity feed to the master cylinder and then used a handheld vacuum pump at the calipers which got allo the air out aok.
Pic shows the 1 piece rear beam bushes taht are much stiffer duro than the superprp ones too, the machined aluminium spacers between the stub axle and beam to widen the track and also it is fitted with Speciality Shims to give roughly 2-3mm toe out total and 2/1/4 neg camber. This beam had wheel studs fitted to it too. All done and ready for some future track action.
