Originally Posted by
sambb
In other suspension news, I'm going to press out the super pro rear lower control arm (caster bushes) and press them back in in a different position. I'd previously run them in the outer most 9 O'clock max caster position because at the time the only way I could get max caster was at the subframes (bush position + subframe eccentric bolts). But now that I've got strut tops its not super important to get it all at the bottom and I need to be mindful that I need 225/45/16's to fit so cant run the tyre as far forward at the bottom as I had.
What I want to do is either press those bushes back in at the 6 o'clock position to reduce anti-dive/pro-lift or choose a 7/1/2 O'clock position that is a middle ground between the min anti-dive and max caster position. thoughts pleeease........
I always go with the maximum caster I can get, particularly on a FWD car as it reduces the need for excessive camber, which helps with the straight line traction (more tyre contact patch). Try the strut top adjuster at max caster and see if the tyres clear then.
Gary
