Lots of questions Sam, hope I don't miss any.
I have seem lambda down to .75 work well, but that was on E25, so .79 on E20 isn't outrageous.
As per previous posts, I have never used a gap below 0.7 mm (28/1000), so my suggestion would be a coil upgrade if you need to further reduce the plug gap. You are going to need it eventually anyway.
In my experience more ethanol ALWAYS reduces knock, due to the cooling effect. There is a point where adding more no longer reduces the knock, which is where I stop.
You are correct, more cam overlap reduces the combustion pressure and hence the knock. But as usual you don't get something for nothing, there is a torque loss, but you do get a bit more exhaust turbine efficiency. So as usual it's a trade off, if it's in an rpm range where you need instant response then more cam overlap isn't a bad thing.
Spark blow out results in a sudden rich spike of unburnt fuel, ethanol does have an oxygen content so it's not as noticeably rich as with pump petrol.
I have always used copper spark plugs for ethanol, at the end of the day copper is better conductor of electricity than iridium and platinum, which are really there to prolong the intervals between plug changes. I have never had an engine run better on iridium or platinum spark plugs.
Topping out the MAF, now there is a good thing, more air = more power.
You know my thoughts on ethanol, best thing I ever did was to change when leaded Avgas became unobtainable from Bankstown airport and unleaded race fuel was $7 a litre (~$500 a race weekend in fuel alone). We used to mix our own E85 about 15 years ago, and then started buying it around 2008 when the United servos stocked it.
Gary
