Page 13 of 31 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 309
Thread: Sams Polo 3.0
  1. #121
    Apr 2015
    The only downside is we can't rotate tyres front to rear, so instead of carrying 2 spares (1 x Left and 1 x Right) we have to carry 4. An upside is that the 205's are cheaper than the 225's.
    Gary
  2. #122
    nsw
    So my compomotive 16 x 8's with 225/45/16 are 18kg. As a point of reference what were the RPF01 16 x 8's with the same tyres?
  3. #123
    nsw
    sad. Sabine Schmitz died. She was good value..... and fast! watch
    Sabine Schmitz Last Moments Before Her Death - YouTube
  4. #124
    nsw
    Got an oil cooler plumbing question as I have to redo most of what came with the car. I thought it had a thermostated sandwich plate but its plate just redirects the flow without any temp regulation.
    So is it usual to go pump/housing>thermo plate>cooler>plate return>filter OR do you filter first and then send the oil out to the cooler?
    Also in a vertically mounted cooler does it matter if you bring the pumped source oil in at the base or the top?
    edit: I should clarify. The car is running a remote filter so I have the option of doing the oil cooling either pre or post filter.
  5. #125
    Jun 2011
    I would say filtering pre cooler would be better, in case foreign objects slowly create a blockage in the cooler core.
    Pump side on top to assist gravity draining at the bottom?
  6. #126
    Apr 2015
    Quote Originally Posted by sambb View Post
    I can't say as I have weighed them with tyres recently, without tyres the RPF1 in 16 x 8 weighs 7.1kgs and the TE37 weigh 5.7kgs. From memory the RPF1 and tyre together was 16.something Kgs I think those tyres were brand new so full tread and weight. I'll be at the workshop tonight, I'll try and remember to weigh a couple.
    Gary
  7. #127
    Apr 2015
    On a wet sumps system I run oil pump ---> filter ---> cooler ---> engine. Keeps the gunk out of the oil cooler and lines. Oil coolers are basically a throw away if you lunch an engine with the cooler plumbed before the filter.
    I'm not a fan of mounting the cooler vertically, but when it is unavoidable I plumb the oil pump output into the bottom of the cooler to make sure that there is no air trapped in the core (which can happen if you run the feed into the top). I also run the engine up on the starter motor first (no spark plugs, fuel pumps off) to make sure that there is no air trapped in the cooler, lines or the remote filter.
    Gary
  8. #128
    nsw
    Jeez the volks are light arent they. I didnt realise the RPF01's were as light as that too. They are in my gumtree/ebay keyword alerts as of now so that hopefully I come across a pair.
    RE the oil cooler thats what I thought. Makes sense and its logistically easier for me RE plumbing doing it that way. Just wanted to be sure. By having the remote filter I can now run with the oil/water heat exchanger in place (good for street/hillclimb minimum temps) and will have the flow to the oil cooler stat controlled so I should have best of both worlds with that setup. Time to drop some bucks on a few more pushlock fittings and then i'll crack on with that.
  9. #129
    Apr 2015
    The 16 x 8 RPF1's are a bit heavier than they need to be, they actually have the 15" centres and the 16" barrels are bellied down to fit the smaller diameter. As a comparison the 17 x 9 RPF1s that I have on the Skyline are 7.3 kgs, so only 0.2kgs heavier than the 16 x 8's. If Enkei had used a 16" centre then they would be probably ~0.4 kgs lighter. That's why the TE37's were appealing.
    To bad you don't have 5 x 114 as there are 2 sets of RPF1's not being used any more.
    Oh and we had a couple of issues last night so I forgot to weigh the wheels with tyres.
    Gary
  10. #130
    nsw
    Sams Polo 3.0-img_1612-jpgSams Polo 3.0-img_1613-jpgSams Polo 3.0-img_1614_2-jpgSams Polo 3.0-img_1615_2-jpgSams Polo 3.0-img_1616-jpgSams Polo 3.0-img_1617_2-jpgSams Polo 3.0-img_1618_2-jpgSams Polo 3.0-img_1620-jpgSams Polo 3.0-img_1621-jpg
    Finally got around to doing a DV relocation to just in front of the TB. I'd done this on the last car and found better boost response after gearchanges, quieter DV operation (less BOV'y) and negates the compressor surge that my car gets when I reverse up the hill out of my garage (that no doubt my neighbours hate me for).
    My car has A Harding performance 2/1/4in pipe from IC to TB which opens up to 2.5in just before the TB. Pipe is 2.5in with 1"tee for the turbosmart DV. Basically wherever you do this in the pre throttle body area, just run the DV output hose around to the stock location in the TIP and make sure you plug in the hot pipe where the DV used to be fed from.
