Page 10 of 31 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 309
Thread: Sams Polo 3.0
  1. #91
    nsw
    Getting closer on the front suspension. Made up brackets for the fitment of droplinks straight onto the arms. They'll sit a little outboard of the ends of the anti roll bar but positioning them half way between the ball joint and inner LCA pivot made it pretty certain what change it was going to make at de-rating the existing 24mm FARB.
    Sams Polo 3.0-img_1472-jpgSams Polo 3.0-img_1480-jpgSams Polo 3.0-img_1482-jpgSams Polo 3.0-img_1479-jpg
    They're with the local engineer/fabricator getting welded so I should have them back in a few days and then I can suss out whether i'll make my own droplinks out of sphericals or maybe adapt the superpro ones I'm already using.
    Attached Thumbnails Attached Thumbnails Sams Polo 3.0-img_1476-jpg   Sams Polo 3.0-img_1478-jpg
  2. #92
    Apr 2015
    That'll work, could have made them double shear but probably unnecessary.
    Gary
  3. #93
    Apr 2015
    There were a couple of Polo's at Wakefield yesterday;
  4. #94
    nsw
    The arms are with Andrew that ran that Silvia in IPRA years back. I guess we'll see how they look once done and decide then whether they need gussets or an extra plate top and bottom, but as it is there's a fair bit of surface area for the welds so it should be ok.
  5. #95
    nsw
    I'll check out the times - curious to see what times they were doing. Thinking of checking out Luddenham on feb 17th but only have road tyres at this stage. There's not any second hand 225/45/16 a050's kicking around your garage are there Gary?
  6. #96
    Quote Originally Posted by Sydneykid View Post
    Needs a lot more black this one
  7. #97
    nsw
    a germanic night rider
  8. #98
    nsw
    How to make a WRC car - behind the scenes at M-Sport - YouTube
    Watching this vid on M-sport UK and their prep of WRC rally cars. noticed in this spot that the coils on this engine look suspiciously Audi R8
  9. #99
    Apr 2015
    Quote Originally Posted by sambb View Post
    Andrew knows what he is doing, should be fine.
    There is a selection of 225/45/16 A050's at the workshop, if you are free on Saturday Justin will be there, I probably won't be. Give me a call and I'll arrange it.
    Gary
  10. #100
    nsw
    Sams Polo 3.0-img_1501-jpgSams Polo 3.0-img_1502-jpgSams Polo 3.0-img_1503-jpg
    With Bathurst looming and the car way off being ready I badly needed to pull my finger out and get it track ready. First thing was getting all the gear mounted into this car for the race seat, harness etc. It always feels a bit criminal taking to the carpet to expose the seat mounting frame but it has to be done. I took a bit more care mounting the two crotch strap eye bolts so that when the stock seat goes back in they dont foul on the under seat tray/compartment. All sorted now and can tick that one off.
    Here's the run down on the seat from the last car: starts here post#1308 Sam's build thread
    Sams Polo 3.0-img_1520-jpgSams Polo 3.0-img_1521-jpgSams Polo 3.0-img_1522-jpgSams Polo 3.0-img_1523-jpg
    follow up to the lower control arm mods: I got the arms welded by a pro and they came back beautifully done. With a coat of primer and paint they look legit and armed with Audi TT RS ball joints, new superpro bushes and complete with my old subframes that have the rear LCA bush pressed in at the 'max caster position', they are now in the car. Fitting it all up didnt go without a hitch though. When I went to bang out the passenger side ball joint, I freaking nicked the CV boot with the drift. Luckily I had a rebuilt driveshaft under the house that I could put straight in, but jeez, not a good way to start a job like this. Also with the rear LCA bush at full caster, and the subframe eccentrics set to max caster on the back and min camber on the front, it was very hard to get the front LCA bolt to line up. I'd set the front of the subframe in because otherwise I was going to have excessive negative camber with the audi ball joints. After lots of grunting, sweating and mozzie bites I got it all together.........literally 8 hrs later! But it really is amazing the effect of all that caster and the ball joints. I drove to work last night after a quick toe plate alignment and the car felt better than before without even running an anti roll bar.
    I made up a pair of drop links for the front usimg 10mm threaded rose joints into the only steel tube I could find that I could thread into - thick walled industrial hydraulic pipe. It should be fine, there's only about 10mm of free space between the engaged threads and it is plates so it should last. If not I'll make something out of solid aluminium down the track. So i'll get them on tonight and i'm super pumped to see how the conversion has worked. I have no idea how taking the effect of steering angle out of the FARBwill feel and fingers crossed that retaining the 24mm bar yet running the droplink pick ups half way along the arm lands me at the right front roll stiffness. I do not want to get under there again for as long as possible so its the 24mm bar no matter what for the forseeable future.
    I'll get some pics of the how far forward the wheels are in the arches and the camber and droplinks in a bit.
    So all I have to do now is zero in on the right setup for the tune (still trying to bodgy the correct boost/timing in Lemmiwinks with the APR tune so it doesnt rattle its head off) and find some rubber and then I can enter the Bathurst Hillclimbs!
