Static compression ratio is not as relevant as many believe and it's getting even less relevant as controlling inlet air temps becomes more sophisticated and hence accurate. Lowering the static compression ratio is a bandaid over the real problem, which is excessive inlet air temps. Very inefficient turbos create extremely high levels of heat in the combustion process especially when pushed beyond their design limitations. You have already hit on the alternatives;
1. E85, you work within walking distance of 2 of the biggest outlets of E85 in Sydney so I don't go much on the limited "availability" issue. For sure it's pain not having every servo selling E85 and it's extra PIA having to plan ahead when travelling to events. But having used E85 for over 10 years you just get used to looking up where E85 is available and planning the route and timing in advance. For sure it's an inconvenience but the gains are well and truly worth it.
2. A lot of guys with combined track and daily driven cars have either 2 tunes or, the more simpler, 2 boost limits. From as radical as an E85 tune for the track and a Pump98 tune for their daily driving. I see lots of guys at track days whip their lap top out, load the track tune and fit their track tyres. Then do the reverse before they head off home at the end of the day. There are also a number (albeit smaller) that simply turn the boost up for the track day, often adding a % of E85 and/or turning the water methanol injection and/on or turning up the intercooler spray and/or adding some methanol to it.
3. Water to air intercooling will be the way I go next time around, then I can simply add ice from the esky to the water reservoir to get lower than ambient inlet air temps. For cars using an airflow meter and inlet air temp compensation that doesn't mandate loading different tunes.
Lowering the compression ration from 9 to 8.5 (for example) might make 2 degrees difference in the timing, whereas any or all of the above can make 10 degrees difference, as you have found. I'm not a big fan of bandaids, when fixing the real problem gives far better results.
Gary
