Probably an opportune time to point out that if you went to E85 it wouldn't matter much what the spray pattern is because ethanol atomises so much better than petrol. eg; at 100 degrees C injector temp Ethanol atomises (wider & less dense spray pattern) ~20% better then petrol. Then add the additional ~25% E85 required and we end up with a ~45% improvement in atomisation and spread at engine operating temperatures. It's not all good news (when is it ever), at say 20 degrees C E85 is 30% worse than petrol. Hence why it takes some tuning to get the cold start and run nice.
Gary
