![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
sambb
Thanks mate. I'll definitely have a read. I didnt even know this was possible until Seb from Eurorevolution tld me it was possible. When my left knee finally goes turd it'll be DSG time so to have it in my car would be awesome.
Hey I was going to contact you re the injector cups. I just found a set of new ones for my large port AGU mani. What adhesive/sealant/epoxy did you use to fit them. Dont want to use the wrong compound and find that the cups heat up/crack/deteriorate.
I may have found a way that I can fit my shorter bosch EV14 injectors (same length as small prt injectors) in to the AGU mani that normally uses 60mm longer injectors. You can use cups that extend the length of the injector but I think i'll do this as a more reliable method: https://forums.vwvortex.com/showthread.php?3598653
That way I can use the existing small port fuel rail which I know is compatible with the bosch ev14's on the top side, and hopefully their O-rings will seal correctly into the large port cups. I have been told the large port cups are made for wider O.Dmm injector O-rings but from what I can find people use small port size washers in them no problem......grain of salt with that though, so more research needed.
