Results 1 to 10 of 1896
Thread: Sam's build thread
    Jun 2011
    Sam's build thread
    Internet says the 20mm rods are on the limit at around 330ft/lb torque. Which is the same as the 19mm rods, so the pin size isn’t the weak factor yet. It’s just the 19mm has no, or very little aftermarket support. Majority if not all aftermarket rods are 20mm
    K04-22/23 on E85 with an aggressive map can bend rods.
    Jun 2011
    Sam's build thread
    Double post
