Originally Posted by
sambb
Also they are all small port heads/inlets which is definitely what I want to stick with.
Why? The reason for small ports is to keep up the airspeed, which is important in an N/A engine but next to irrelevant for a turbocharged engine. All that small ports do is increase the boost because of the restriction that they present to the airflow. Boost is after all a measure of the engines restriction to airflow and it's airflow that makes horsepower not boost. In simple terms I'd much rather have an engine that makes, say, 300 bhp at 15 psi than one that makes 300 bhp at 25 psi. There is less load on the turbo plus less heat generated which means a smaller intercooler and/or lower inlet air temps. Of course there are lots of other benefits, lower combustion pressures, lower water and oil temps, less time spent recovering to full boost (lag), etc. Larger valves (particularly exhaust) for the same reason.
Personally I'd be looking for a cylinder head that fits on the engine with the largest ports and valves that I can find.
Gary
